GM steering wheel audio control buttons
Old 09-06-05, 11:59 AM
tcarr680
Post GM steering wheel audio control buttons
I have a 1999 Grand Prix GT. Recently the lights went dark inside the steering wheel audio control buttons on both sides.
They still function perfectly otherwise. I checked the fuses near the glove box and they were good.
Is there anything else I should be checking or do the lights in these buttons have a tendency to just burn out?
How easy is it to change these buttons? I'd prefer to have them lit if at all possible since I drive at night most of the time.
Thanks in advance for your advice.
TC
Old 09-06-05, 07:21 PM
Quite often, we see this problem. The bulbs/led's inside the switches go bad. And that means you have to replace the switch since those bulbs/led's are non-servicable. On your car, I beleive they just push into the steering wheel. So you will need to "dig" them out with a pocket screwdriver, or a small screwdriver. Be careful when doing so, so you don't damage the appearance of the steering wheel.
Old 09-09-05, 02:17 PM
B
How easy is it to set off the airbag while trying to remove the buttons?
Old 03-02-07, 06:27 PM
G
buttons come out real easy. i could pry mine out with a key. All 3 button will come out at the same time. It is a big switch..
