back up lights 98 elantra wagon
Old 09-08-05, 02:08 PM
pjoyal
I have a 98 Elantra wagon. the back up lights are not burned out. Yet when I put the car in reverse the lights do not turn on. I assume there is a switch that is engaged when I put it in reverse (this model is a standard) but it isn't engaging. I'm wondering if you know where it would be located and how to access it.
Pierre
Old 09-09-05, 09:13 AM
DNT1
Not sure on this particular vehicle but typically they are located on the side of the trans it will have some wires running to it and you can see where the shift lever makes it turn, it should not be hard to spot. Do you have a new puppy around your house? they really love to chew on those wires I quess to sharpen there teeth. I have lost cruise control just recently due to that problem.
