mixing of oil grades
Old 09-11-05, 09:47 PM
B
I would like to know if I could mix 5W oil with 20W oil. My 2000 Montero Sport takes 5 quarts of 5W-30 or 5W-40. When I change my oil can I mix one quart of 20W to 4 quarts of 5W. Will this do any harm to my engine. I have about 36Kmi on it. Thanks.
Old 09-12-05, 03:21 AM
C
why
Why would you even be considering this? just put 5 qts of the weight you want!!!
Old 09-12-05, 04:19 AM
...I don't think it will do what you are thinking, mixing two straight weights to make you own multi-grade
Old 09-12-05, 06:29 AM
Received 408 Votes on 364 Posts
I don't even like to mix the same weight oils with different brands. You have a low mileage engine - take care of it and use good oil of the right specs
Old 09-12-05, 07:19 AM
G
Received 2 Votes on 2 Posts
If the manufacturer specifies 5-30 or 5-40, that is what they believe works best with that engine. Don't try to customize oil. Straight weights may not have the same additives and friction modifiers as the multigrade product.
Old 09-12-05, 10:38 PM
B
Thanks. I have a case of 20W-40 and hate to waste it. I know I'm penny wise dollar foolish. I'll use the 5W and hold on to the 20W. Not sure what I'll ever use it for. I'm too cheep to toss it.
Old 09-13-05, 04:35 AM
the_tow_guy's Avatar
Received 67 Votes on 56 Posts
Might be a little heavy for small engines, but you could always keep it for the annual oil change in your lawnmower.
Old 09-13-05, 10:25 PM
B
Not a bad idea. I'll have a 12 year supply of oil for the mower.
