ABS light
Old 09-13-05, 06:28 AM
E
Question ABS light
97 Bonneville over 200K
My ABS light came on and then I started noticing shaking in the front end. I checked the tires and noticed one tire had warn out unevenly. Probably due to bad alignment. I changed the tire. I had no more shaking in the front end. However, the ABS light is still on. What could be causing this and how do I get it to turn off?
Disconnecting the battery doesn't work.
Old 09-13-05, 04:25 PM
D
abs
Chances are you have a bad speed sensor/hub bearing or a broken wire to a sensor.You will have to have someone witha good scan tool check the codes so you know where to go with it.
Old 09-14-05, 08:28 AM
E
Thanks, I will follow up that.
