headlamp bulb replacement
Old 09-13-05, 11:31 AM
landrew
Unhappy headlamp bulb replacement
[I want to replace the headlamp bulbs on my 2002 olds bravada, how do i remove the old ones?? This would be different than trailblazer & envoy because of the smaller grille. thanks in advance..
Old 09-21-05, 09:06 AM
landrew
Talking
: :thumbup: :D :D [=landrew]: [I want to replace the headlamp bulbs on my 2002 olds bravada, how do i remove the old ones?? :) This would be different than trailblazer & envoy because of the smaller grille. thanks in advance..[/QUOTE]SOLVED IT MYSELF INABOUT 30 MINUTES BOTH SIDES :
Old 09-21-05, 09:13 AM
landrew
Figured It Out Myself, Did Both Sides In About 30 Min. 2 Black Slide Latches Hold In The Headlight And Grille Bucket Plus 2 Spring Catches Toward Center Of Grille. Careful With These When Trying To Release. Pull Assembly Forward And Disconnect Power And Turn Signal Bulb. Remove Round Rubber Cover, Turn Bulb Holder To Disengage And Remove Old Lamp.
