92 toyota
Old 09-16-05, 07:59 AM
mike1342
92 toyota
I have a 92 toyota 4wd pickup with a 22re and a 5 speed tranny
it will cut out above 2000 rpms and come back on just like if your where to turn the key of for a second then turn it back on it will continue to do until i shift to a higher gear and the rpms drop below 2000
I changed the fuel pump about 2 years ago and changed the fuel filter and plugs about 8 months ago
I drove it today and it didn't do it it just happens time to time
Mike
Old 09-17-05, 04:41 AM
the_tow_guy's Avatar
Received 153 Votes on 118 Posts
How fresh are the rest of your ignition components, including the plug wires?
Don't remember the exact setup for components on that, but cap & rotor also for starters. Other possiblities would be the coil or ignition module (if it has one) that are being affected by heat.
Wouldn't hurt to have it checked for codes, too.
