1991 Honda Accord Door Handle
Old 09-16-05, 02:04 PM
CFMPC
I have a 1991 Honda Accord and the drivers side door handle is broken(2nd time). It has to be easy to install another handle but I don't know how to begin. Anyone out there who could give me some good instructions?
CFMPC
Old 09-16-05, 04:37 PM
D
You can buy a Hanyes repair manual from any local auto parts store. It has details description plus helpful pictures. Good Luck!
Old 09-16-05, 08:05 PM
W
if you look behind the chrome part of the handle you will see a small circle about 1/4" in diameter, this is a cover for the screw that holds the handle in place. gently pry it off with a small pick or eyeglass screwdriver, and remove the phillips screw underneath. push the handle towards the front of the door about 1/4" and then pull it away from the door panel. now you can reach behind it and release the rod.
