Broken throttle body gasket
Old 09-16-05, 02:41 PM
Ken Dizzle
I was putting in hondata intake manifold gasket in my acura rsx, and in doing so i had to remove the throttle body.
When removing the throttle body i broke the throttle body gasket.
How bad of a problem is that and should i order a new gasket?
Old 09-17-05, 04:23 AM
the_tow_guy's Avatar
Received 153 Votes on 118 Posts
Well, the gasket is there for a reason. Any air leakage could have negative effects on performance. Replace it; shouldn't be expensive. Not likely to cause any problems if you had to drive it for a couple of days.
