'96 chevy corsica surpentine belt
Old 09-20-05, 06:13 AM
vmiller83
Question '96 chevy corsica surpentine belt
it looks to be starting to fray.. does anyone know how to replace one of these? it's a v6 engine.
Old 09-20-05, 08:23 AM
Replacing the belt is not as bad as it may look. There is usually a picture of proper belt placement under the hood, it will show you how to place it over the pulleys. You will need a wrench possibly an 18mm or it may take a ratchet. You will use this to release the tension from the tensioner pulley and then the belt will come off, then follow the picture for proper belt placement. If the picture is not available try checking with you local library for a repair manual. Good luck!
Old 09-20-05, 04:15 PM
vmiller83
thanks for the info!
