need help!
Old 09-21-05, 02:55 PM
need help!
got a '99 pontiac bonneville and the turn signals don't blink when I use them, they stay on ( not blinking ), is the problem a fuse or I have to replace the flasher?, the emergency lights work, if it is the flasher can you tell me where is located. Thankyou in advance for your help.
Old 09-21-05, 05:14 PM
It is probably the flasher. It is often identical to the emergency flasher. Most are located on the fuse block. An easy way to identify it would be to turn on the 4 way flashers, find the flasher relay [it will be clicking] and look for a similiar flasher near it.
Old 09-22-05, 11:58 PM
I can't find it, do I have to take a plastic cover under the stearing wheel?
