pontiac
Old 09-23-05, 05:06 PM
pontiac
need help how to locate the turn signal flasher, I found one but I thinkis the one for the hazard lights, is it the same?, the hazard lights work, they flash, but the turn signals don't, they stay lit, any advise? thanks
Old 09-23-05, 07:11 PM
It should hopefully be near the hazard flasher and look the same.
If you see two, turn the hazard flashers on, find which one is clicking, and replace the other one.
Old 09-23-05, 07:30 PM
finally
I found it! it was it was in a place really hard to find, question; is there something wrong with the car or it is normal for them to brake?
Old 09-23-05, 08:23 PM
It's not unusual for flashers to go bad.
First, check all the exterior bulbs and make sure they work. A non-working turn lamp can cause the same symptom.
