87 Tercel electrical problem
Old 09-24-05, 05:26 AM
R
Question 87 Tercel electrical problem
It's an 1987 Tercel wagon, 4 cyl 5-speed. Starter went out, replaced it. A few months later, began having incidents where turning the key to start would not engage starter, but the interior lights, underhood light, radio, etc worked fine. Repeaded tries would eventually start the car just fine. Over time, it progressively took longer and longer to get the car to start, and now it's totally dead. Replaced the battery with no improvement... No interior lights, radio, or any sign of current flow in ANY part of the car. Cleaned battery cables and inspected all wiring between battery and starter, but saw nothing unusual. Could the ignition switch cause this, or maybe the starter itself? Or what else should I focus on? I'm desperate to get this econo-box back on the road!
Old 09-24-05, 07:23 AM
Check the smaller wire attached to the pos terminal (maybe white), also check the larger fuses in the underhood fuse panel
Old 09-27-05, 10:08 AM
toyomen
hey
chech your inigtion or your alternador may be is the problem ok
Old 09-27-05, 09:28 PM
Cherry
starter relay or sarter solonoid
turn the key as if u are trying to start it and see if u have power at the small wire that goes to the starter
