94 Chevy 4x4 truck transmission Quirks
Old 09-27-05, 11:19 AM
94 chevy, 350, 3.5L. 4x4, automatic transmission
last spring the transmission started to shift down without reason on the freeway. Once the weather warmed up....... it started to work normally. Now that it has cooled down again.... it is back. Are there any sensors that go bad? Any ideas?...... Thanks
Old 09-27-05, 09:25 PM
Cherry
when have u changed the filter and tranny oil
when oil is cold it is thick and if the filter is plugged up somewhat only some oil can get threw until the oil get hot again and thins out
start by changing the filter and oil in the tranny
Old 09-27-05, 10:08 PM
Thanks Cherry for the info. My reference to it "warming up" meant that summer came and it started to work normally. Now that it is cooling down again, it is shifting down to the passing gear for no reason and back up to overdrive eradictly. However, the oil change in the tranny can't hurt. I should have been more detailed.....i keep getting booted trying to post threads. Thanks
