2k Grand prix se drivers window cable came off
Old 09-27-05, 02:13 PM
FRUSTR8ted_1
The cable on the drivers side window came off the track on the bottom of the window. The motor is working, the cable is in tact, can anyone tell me how to get the cable back on so that the window will raise and lower? The help would be greatly appreciated! Thanks
Old 09-27-05, 04:40 PM
If the cable came off, a clip or something had broken. We see this in the shop quite a bit and we replace the regulator assembly. Some vehicles, GM came out with a TSB on replacing just the clips that help hold everything together, but I think it was just for the Rendezvous and the Aztek. I would say just replace it to prevent it from reoccuring over and over agian.
Old 09-28-05, 11:42 AM
FRUSTR8ted_1
Thanks
Thank you for the quick reply, I really appreciate it. I thought that this might be the case, but just wanted some verification before going to the expense and having it not be the solution. Thanks again.
