air conditioner on 2002 Dodge Van
Old 09-29-05, 03:37 PM
biketrailer
I have a 2002 Dodge Caravan. My problem is with water gushing down on the carpet on the front passenger side of the van. The water flows out when I accelerate and onto the carpet. Is the water backing up from the a/c or from the water when it rains. If it is the a/c drain, how do I unplug the drain?
Old 09-29-05, 04:33 PM
BILLCHA44
Gushing water
look under the hood for a rubber tube assy, there are two one on each side, that are located about at the bottom of the area where the windshield wipers sit called the "COWL", look around there for the tubes and you should be able to see if they are clogged with leaves and dirt. they will look like a tube about two inches thick but almost flat. the water isn,t draining and overflowing into the air inlet for the
heater and a-c assy.
if that doesn't fix it then you will have to get under the truck (!!!safely!!!), and look on the bottom of the right side-Passenger- of the firewall assy and look for a tube for a-c drain. same thing see if it is clear.
by the way you mentioned it it seems like the COWL drains I mentioned first.
