86 Civic 1st gear
Old 09-30-05, 10:59 PM
86 Civic 1st gear
86 honda civic 5 speed
1st gear is hard to find. When it does go in gear it works fine. Some times have to take off in 2nd.There is no grinding when trying to find gear.Can this be a adjustment or is the trans going out? Someone said to try Trick Shift it might help.
Old 10-03-05, 05:28 PM
bigmuffler22
Exclamation
try to let out on the clutch some not all the way at the same time try to put it into 1st the clutch might be to tight and going past the opening for 1st or your cable might be looose to the transmission good luck
