can't start car - key won't turn
Old 10-01-05, 06:50 AM
My son owns a '99 Sunfire. Everytime he puts the key in the ignition it doesn't turn. He has to mess around trying to turn the key several times before it finally turns. Does anyone have any ideas? Do we have to change the ignition switch? Thanks for any help.
Old 10-01-05, 09:18 AM
The key cylinder is coming apart or gummed up inside. You can try using rust penetrant in the cylinder. Insert the key and tap it LIGHTLY with a small hammer. See if that helps to free it up. If not, the cylinder will need replacement.
Old 10-01-05, 10:22 AM
If he's got a spare key with a little less "wear" on it, try that one. Sometimes, the wear from continual insertion into the ignition will erode just enough surface off the key so that it won't work any more. The same thing just happened to me, and the spare works like a charm.
Pecos
Old 10-01-05, 06:29 PM
It may be just the key, but I'm thinking its the lock cylinder also. These and the Cavaliers have problems with the tumblers inside the cylinder. They become worn, as does the cylinder itself. The tumblers begin to corrode inside the cylinder. The cylinder is aluminum and the tumblers are brass. Any bi-metal mating surface will eventually begin to corrode. So, if the other key don't do the trick, replace the cylinder and have it recoded to match the old keys.
