95 Buick Regal 3.1 Power Steering Hose
Old 10-03-05, 11:37 AM
Iím working on a 95 Buick Regal and so far Iíve had to change the pressure hose 2 times, and I have to change it again. The first time the pressure hose somehow got punctured and we simply replace it. The second time it got punctured in the same spot we thought it might have something to do with the Power Steering Pump. So we changed both the power steering pump and pressure hose. Now it happened again and in the same spot for the third time, the pressure hose got punctured. It keeps getting punctured where the pressure hose curves to the power steering pump. Is there any other reason the pressure hose would get punctured other than the power steering pump? And any clue to why itís getting punctured in the same spot?
Old 10-03-05, 12:07 PM
It is most probably hitting a moving part. You can have a steel braided hose made to order by any hydraulic place. If the hose is collapsing and not hitting a moving part you may want to have the curve made of steel and have a three piece hose made.
Trackbacks are On
Pingbacks are On
Refbacks are On
