'04 Nissan Titan scratches
Hello,
I received multiple small scratches from a parking garage on the driver side back door of my Nissan Titan. The color is deep water blue. I would like to fix this myself. Do you recommend any certain kits to use to redo these small scratches??
Thanks,
Joey
Thanks,
Joey
If they are very shallow and light, try using polishing compound. Find it on the same aisle as the waxes. Bes ure to get polishinhg, and not rubbing, compound. The rubbing compound is more abrasive. Be sure to follow the directions.
Here's some useful info on touching up if it requires more than the polishing compound:
http://www.paintscratch.com/automotive-paint-tips.htm
