94 Mercury-topaz
Old 10-03-05, 10:46 PM
G
94 Mercury-topaz
I´m having a wierd problem with my car. if I use turning lights it self, it's ok, but if while turning lights on I turn on the hazard lights it does not turn on and it shut down the turnig lights.
If I turn the hazard lights on it self, it will not come on!
If I have the hazard lights switch at the on position and I turn the turning lights on, it will not come on!.
What could it be?
Any help will be apreciated
Old 10-04-05, 06:08 AM
A
Sounds like the fiasher for the hazard lights is blown.DO the hazard lights come on any time? If not it is the flasher.
Old 10-06-05, 11:48 PM
G
No, the hazard lights will not come on under any situation, if it is the flasher how do I check it or fix it? . Thanks for reply.
Old 10-10-05, 01:54 PM
A
The flasher should be around the fuse box or around the steering colum.Turn directional on.The noise you hear is the flasher for the turn signal.Locate it and then look for another one.This should be for the hazard lights.Make sure it is pluged in good or replace it.You could buy one to see what it looks like.They are under $5.
Old 10-10-05, 02:02 PM
A
REMOVAL & INSTALLATION
The hazard warning flasher is located on the rear side of the fuse panel.
Locate the hazard flasher in the fuse panel.
Pull the flasher out. DO NOT TWIST.
To install:
Push new flasher into place making sure a good contact is made with both terminals.
Test flasher to make sure they function properly.
