Running Bad
Old 10-08-05, 08:07 AM
Unhappy Running Bad
undefinedundefined
I have a 97 chrysler sebring. It's a 5 speed. It doesn't want to stay running until it warms up. Starts and then dies right away. Runs sluggish and stalls when i first accelarate then it seems ok. The check engine light came on. I got a code for the ignition coil. I replaced the coil pack and the sparkplugs. It still does it. I still get a code for the ignition coil even after replacing it. I live in Ohio had it e-checked for plates the reading from that said i had miss fire in cylinder 2. could it be there wires? they look ok. also got a code for the oxygen sensor.
Old 10-08-05, 03:47 PM
New Member
Check the wires with an ohm meter. A bad wire could cause a misfire.
