Windshield Washer pump
I own a 1992 GMC Sunbird and we need to replace the Windshield Washer Pump under the reservoir container, but we are not sure how to remove this???
Can someone please be kind enough to describe how we can remove this container???
Thanks
Thanks
should be easy
You should be able to remove the bolts holding it in remove the electrical connector and the hose off the pump.To remove pump it might be a twist off type.Replace the gasket also.If it does not twist off you might have to remove a large nut on the inside use a extension with a deep well socket.
