Static noise from the speaker
Old 10-09-05, 11:59 AM
97 Ford 150 Reg Cab Long Bed 50K miles.
It started a few months back. When caught my attention was after I turned off ignition key, the speaker became staticky with noise. This morning the battery was drained that it barely cranked the motor (but couldn't start the engine). By the way, the pickup hasn't been driven for 2 weeks. (can a battery go empty in 2 weeks unless there is a drain?)
These static noises are when radio is off. Can I just remove the radio and will the problem disappear? Or the speakers? I don't use the radio and it doesn't bother me if the radio is functional or not. Thanks.
Old 10-10-05, 07:37 AM
chevyastro4x4's Avatar
yes removing the radio will fix the problem
Old 10-10-05, 08:12 AM
Thanks. I will remove the radio this afternoon, and report back to you folk.
Old 10-10-05, 05:50 PM
Removed the radio. Static noise is gone. I don't miss the radio, but a big gaping hole in the middle of the dashboard doesn't look right. I think I will buy a MP3 CD player to listen to my favorite book reading. I hope the static doesn't return. Thanks.
By the way, I also replaced the battery. I can't believer Ford F150 uses such a small battery (the smallest of all at WalMart). No wonder it went bad in about 3 years.
Old 10-10-05, 07:35 PM
What Size Cranking Amps Is It? If The Noise Comes Back Then There A Problem In The Wiring Or A Speaker Is Bad
Old 10-10-05, 10:18 PM
Battery chart recommends 540 CA and 450 CCA, the smallest of all WalMart batteries. I didn't like it at all. I put an oversized battery 850 CA 700 CCA.
If noise returns, now I know what to do next.
Thanks again.
Old 10-11-05, 06:26 AM
You'll Welcome, Ya My Car Recommends A 850 Or Bigger
Old 10-11-05, 07:06 AM
Just wondering
Did you try to remove the radio fuse before removing the radio?
Old 10-11-05, 07:33 AM
there still would be power going to the radio from the memory wire
