Squealing brakes
Old 10-10-05, 08:56 PM
hotwire58
Squealing brakes
1995 Dodge Intrepid - I had the breaks repaired because they were squealing and the pads were bad. On the front we replaced rotors, calipers and pads.
On the read just the pads were bad. They continue to squeal almost as soon as you touch the brake pedal. Any suggestions?
Old 10-10-05, 10:46 PM
Betaguy001's Avatar
You may find that some brands of pads are better than others when it comes to squealing. You can also look for an anti-squeal product that is applied sparingly on the backside of the pads where the caliper piston presses against them - that's usually where the squeal orginates (when the pad just begins to touch the rotor and the pad/piston contact area isn't under high pressure yet). The product is like a paste - sorry, can't recall the brand name...I haven't had to use it for a few years.
