gasket
Old 10-16-05, 12:34 AM
William521
gasket
Hello,
Should you always replace a gasket if removed. I Just removed two metal pieces of off a engine and the gasket is stuck to both pieces. It tore when I removed both pieces but it is stuck to both pieces so if I where to just put the two metal pieces back toghether it should look as good as knew. Thanks for clearing this up for me. William521
Old 10-16-05, 05:10 AM
Originally Posted by William521
Should you always replace a gasket if removed. ..
Yes
Although technically there are a few gaskets that can be re-used, most can't
It tore ... it is stuck to both pieces ...
You'll want to replace this one
Old 10-16-05, 11:11 AM
jatco's Avatar
I would replace both gaskets. From what part(s) are these gaskets from?
Scrape off the old gaskets and clean off/up the part(s) where they go and depending on the part, use a gasket caulk/sealant to replace the new gaskets.
