Heater Won't Work
Old 10-18-05, 07:35 PM
CODY
Question Heater Won't Work
Have A 2000 Lincoln Ls. Heater Has Been Working Fine. This Morning It Will Only Put Out Cold Air. Checked Fuses, All Ok. Car Is At Normal Oper. Temp. Have Not Had Any Problem With Running Hot. Doesn't Seem To Be Heater Core, (no Antifreeze Smell Or Fog On The Window)
I Have Tried Disconnecting The Battery And Re-connectint To See If The Computer Will Reset But No Change, Don't Know The Next Move??????????????????? Thanks
Old 10-21-05, 07:21 AM
thiggy's Avatar
Modern high-end automobiles have been specifically designed to foil any attempt to be diagnosed or serviced by shade tree mechanics. Believe me, I know. My wife's car is a '02 Volvo. (It is time to take your car to a trusted independent mechanic.)
Old 10-21-05, 04:38 PM
CODY
Thanks for the response. i believe you are right. if this was my '66 galaxy she would be fixed already . Thanks again.
