automatic transmission shift pattern 91 mitsu
Old 10-20-05, 09:33 PM
chefrn90
I have a 91 mitsu truck 2.4 liter with automatic trans. What are the speeds that it should shift into the higher gears and when should overdrive shift? Can you always feel the overdrive shift?
Thanks
Old 10-21-05, 09:56 AM
Shift speeds
Hi Chefrn90,
The speed at which your truck shifts will be dependant directly on where you foot is on the gas pedal, the more gas you apply the later the shift points. Overdrive may not necessarily be "felt" but you should notice a drop in engine RPM.
Hope this answers your question, Jeff
