84 F-250 diesel no glow
Old 10-21-05, 05:42 AM
Negoshe8n
I just replaced all the glow plugs and the regulator. Still doesn't want to start after sitting for a day or longer without running the new batteries low. Is there another relay somewhere? I'm thinking of checking all the fusable links that I see near that regulator. Thanks
Old 10-27-05, 09:08 PM
Negoshe8n
OK the glow plugs aren't heating up, for sure. Anyone?
Old 10-28-05, 02:03 AM
Ramrod48
glow plugs
check all your fuses , an also theres a conrtoller that screws in the back of the intake mainfold , it operates off engine temp. if the controller is faulty it will not activite the glow plugs , cause it thinks the engine is hot allready , did you hook a test lite to the glow plugs to see if there getting power ??
