96 Ford Contour check engine light is on - code read: P0174
Old 10-25-05, 06:24 PM
sf_power
Hi,
I have a 97 Ford Contour V6. Its check engine light has been on for a while and i went to an autozone and get the code as P0174 with the following description:
"The PCM has determined that during testing, the fuel system for bank 2 was too lean. (Bank 1 identifies the location of cyclinder #1, while bank 2 identifies the cylinders on the opposite bank)"
Any ideas on how I can fix that?
Thank you.
Old 10-26-05, 11:22 AM
This means the MAF (mass air flow) sensor is dirty or needs to be replaced on the side that does not have the number 1 cylinder. I am not sure on your engine which side that would be. It could also mean a vacuum leak.
Check out this link that describes the codes and fixes.
http://www.obd-codes.com/trouble_cod...gen-sensor.php
Good luck.
Trackbacks are On
Pingbacks are On
Refbacks are On
