1996 Ford Windstar heat
Old 10-26-05, 06:30 AM
D
My van is not is putting out very warm air in the heat mode. Any suggestions on where to start looking? The dampers have switched over from the cold air mode is about is far as I got.
Dan
Old 10-26-05, 08:00 AM
mattison's Avatar
Is the radiator full ??
Did it work last season or is the van new to you ?
Old 10-26-05, 10:03 AM
D
It was working fine last year. I didn't check the fluid level but the engine is not running hotter than normal.
Dan
Old 10-27-05, 06:07 AM
hogfan's Avatar
Most of the time it's a Blend Door motor behind the radio and heater control panel. On the heater plenum. Do you hear a popping noise when you turn the heater control knob from HOT to COLD? If so it's the Blend Door Motor.
Old 10-27-05, 08:47 AM
D
Thanks for all the help. The problem has been resolved.
Dan
Old 10-28-05, 03:30 AM
Ramrod48
heat
lots of time I have the cable slip , outta adj , wont flip the flaps
