rear washer pump
rear washer pump
Hi i have a 1996 plymouth voyager 3.0 litre v6 basic model with 34,321 km inherited from my dad ,never winter driven ,when i activate the spray jet for the back nothing comes out ,in the front no problem .i would like to know is there a second washer pump for the back jet and where could i get to it thanks
Don't remember exactly where it is, but in most vans usually found under an access panel on one side or the other all the way in the back. Often there will be a panel on both sides with tire changing stuff in one side and the washer reservoir in the other. You might also check to make sure the nozzle itself isn't clogged. Poke the outlet hole with a very fine needle.
This may be a dumb question but. Did you make sure the rear washer bottle has fluid in it ?? I don't know about the 96' but my 93' T&C had a seperate washer bottle in the rear of the van.
