Rebuilding a rack and pinion
the rack and pinion in my 1991 plymoth acclaim has went out. i have looked every were but cant find instructions on how to install a rebuild kit. any ideas on which web site to look?
rack building
normally the home mechanic can only replace the seals an ball joints , as the inner's require some machine work most times .. However normally you can get a re-built unit for like $90-130.00, comes with a warranty an bolts right up , at most parts stores .
