2000 corolla timing chain tensioner oil leak?
Old 11-06-05, 06:22 AM
I went to Dealer yesterday for a oil change (it was free) and a free lunch to boot
Anyway after it was done I saw a little notation on the bottom of the work order that says timing chain tensioner O ring has oil leak.
I was wondering if this is possible and how can they see that on a oil change?
Engine is a 1.8L.Is the chain not enclosed and lubed anyway?
Old 11-06-05, 07:59 AM
Common and can be seen from underneath. It's bolted into the rear of the timing cover from the outside.
Old 11-06-05, 08:24 AM
Easy fix?
Thanks Larry is this a easy fix? I dont want to disasemble engine if you know what I mean .If so I will just buy a O ring from dealer and do it myself.
Old 11-06-05, 08:56 AM
Pretty easy, remove the two 10mm bolts, replace the "O" ring
I sent you a doc with the procedure for resetting the tensioner
Old 11-06-05, 09:49 AM
Ok
Ok Larry thanks I will check out the procedure I do not see it yet but will keep a eye out for it.
Mike
Old 11-06-05, 10:54 AM
Sent to your email
Old 11-06-05, 12:59 PM
Ok
Alright I found it thank you very much for the help.
