Brake replacement help
Old 11-13-05, 06:43 AM
P
pledesma76
I have a 2002 Ford explorer 4wd v8. How hard would it be to replace the rear brakes (pads & rotors). Any different from the front (which I've already had done)? Is there any step by step instructions online?
Old 11-15-05, 10:52 PM
B
bigdaddy832
Brake replacement
If you have pads on the front and rear they should change out in the same manner. If you've done the front you can replace the rear. good luck!
Old 11-16-05, 09:15 AM
R
Beware some rear calipers need to be pushed in and screwed in like a screw to get the piston to go back into the caliper. Not sure about that application.
