Remote Starter
Old 11-14-05, 08:14 AM
chevyastro4x4's Avatar
Remote Starter
I'm Planning on getting a car alarm that has a remote starter built in. and i was woundering how does the remote starter work without the key turned on?
Old 11-14-05, 12:18 PM
my 2 cents
I have some friends with that system and they now have electrical problems.The systems were installed by stereo stores.
I would be real scared of hacking into stock factory wires to install such a system because of problems down the road.
That is just my 2 cents but you can do what you want.With todays high tech cars were a mili volt can cause problems with computers.
If it were a 60s car no problem.
Old 11-15-05, 10:44 PM
B
bigdaddy832
The remote starter will connect to the ignition wires therefore bypassing the ignition switch. If your car has a key that has to be programmed or an anti theft system, then you will probably need some type of bypass unit installed with the remote starter.
Old 11-16-05, 05:34 AM
Ok Thanks Everyone, I Think I'll Just Suck It Up And Go Out And Start It In The Cold
