95 maxima stuck in park
Old 11-14-05, 11:10 PM
Unhappy 95 maxima stuck in park
my 1995 nissam maxima suddenly will not disengage from park. Is there something I can do to move it to the "N" position?
Old 11-14-05, 11:35 PM
Try putting the key in the ignition, without starting it, turn the key to run, or off (try different positions), while pressing the brake pedal, try to move the shifter. There may be a procedure for this in the owners manual.
Old 11-15-05, 01:21 AM
Thanks for your reply but i've tried the ignition proceedure. It did not work..
My problem seems to be the button that you depress on the gear shift will not
depress in fully to release it from the park position. Any ideas will be welcomed. I'm LOST !!!
Old 11-15-05, 06:01 PM
my 2 cents
I would suspect the park netural saftey switch.It is installed so you must push on the brake to shift from park to any gear.
Old 11-16-05, 12:41 AM
95 maxima still stuck in park...
Thanks My 2 Cents for your post.
I'm so lost, at this point I'll take wooden nickles.
I welcome your point and any advise I can get.
You guys are great! And the site is amazing!
Old 11-16-05, 03:52 AM
Check and see if the brakes lights go on when you press the brake pedal?
