Radiator Repair
Radiator Repair
The top of the radiator has developed a super thin crack
When pressure builds up coolant leaks out of two spots along the crack
I don't know how big water molecules are, but these streams are probably about two or three thick lol
The top of the radiator is not metal, but plastic or some composite
Is there any fix for this or must the radiator be replaced?
Thanks in advance
Thanks in advance
have replaced one in a truck i just got, man used some sort of a epoxy or something he said, it was bulging, getting ready to pop, its a quick fix but i'd replace the radiator. you probablly have a plastic radiator, they are being used now......
If you try to patch it (JB Weld?), do it from the inside. You'll never get a decent patch on the outside. Perhaps you can dry the crack somehow and wick some superglue in there.
The whole radiator is plastic?
Holy Cow
Well it still has metal fins
I'm not sure how I would get to the inside of it
Well, I may have to remove it anyway, for a replacement if repair is not an option
I'll take a closer look at it
Holy Cow
