Resetting computer...TRUE?
Old 11-18-05, 04:59 PM
Someone recently told me that instead of just unhooking 1 battery cable, to disconnect both cables, and touch them together for about 10 sec...supposedly resets computer faster? Anyone heard this before?
91 Chevy Beretta 3.1 V-6 Auto
Thanks..
Old 11-18-05, 08:23 PM
K
Not true, dont do it
generally not a good idea to cross wires
Jim
Old 11-18-05, 08:54 PM
Depends on the system... naturally, you want to be sure that you wont have a power source involved in your battery cable idea. I've used this method before..... much easier is to disconnect the ground and make sure it can't contact the negative post on the battery.... turn on the headlights and go for a pee/cold one/smoke.... Done deal.
Of course, disconnecting both battery terminals is the ideal time to clean those puppies so that they are a shiney lead looking surface.....
Better than clearing the PCM.... fix the problem that makes you do it....
Old 11-18-05, 08:57 PM
K
listen to the man... hes been working on trucks for longer than ive been around
Old 11-19-05, 09:11 AM
K
I've heard this is the way to disarm the air bag... don't know about resetting the computer. I thought just disconnecting the battery would do that.
Old 11-19-05, 08:23 PM
So basically dont try this..lol
Thanks for responses, and must be a no go. I didnt think was a good idea, so thought I would ask. Thanks for the input greatly appreciated....
Old 11-20-05, 08:55 AM
It does't cause any harm, it's just a faster way to "drain any capacitors" that are keeping any memory alive.
Old 11-20-05, 07:23 PM
Thanks Toyotaman..as long as no harm is done. Any idea how long it takes the computer to completely reset?
TIA...Jen
Old 11-21-05, 01:47 PM
Pendragon's Avatar
Also worth noting that disconnecting the battery will only clear 'soft' codes set in the computer. Hard set codes will remain, and of course, if the problem that set either code still exists, it will show back up the next time you drive.
Old 11-21-05, 06:48 PM
From the looks of your other threads you problems are not going to corrected from resetting the computer.
http://forum.doityourself.com/showthread.php?t=241547
http://forum.doityourself.com/showthread.php?t=241874
Old 11-21-05, 06:49 PM
So how do you clear the "hard" codes left in computers memory? Is there a way to do it?
Thanks... ~Jen
Old 11-21-05, 06:54 PM
Thanks toyotaman for response...am just confused with what to try any more. Trying at this point any possibility. I have had this car for almost 5 years and am partial to it, and guess is safe to say when it starts to go, it goes..lol. Thanks for all the help..much appreciated
Old 11-21-05, 07:12 PM
I think what is meant by hard codes are faults that are present. You clear them but they come back immediately because the fault is present.
