92 Ford Explorer stalls
Old 11-20-05, 11:18 AM
paudemge
My sons 1992 Ford Explorer with over 100k miles looks like it has something wrong with the transmission.
He can drive it around our neighbor hood with no problems, however, if he goes a little further it may start to vibrate and then may die.
And then once it has died he can start it ok, but as soon as he puts it in gear it will die. After a few hours it will usually be ok again.
Some times it won't die will driving , but will still have the problems stalling after he stops.
Seems to maybe related to how fast he goes, i'm sure he doesn't exceed about 30mph in the neighborhood, but i'm pretty sure that even if he goes a short distance outside the neighborhood, he probably goes about 35-45mph. Also the longer he drives outside the neighborhood the longer it seems you have to let it wait before you can drive it again.
Could it be a problem with the overdrive? (well it is probably not the OD, because he says he just puts it in D not OD)
Any insight into this before I just bite the bullet and have it repaired.
Old 11-21-05, 04:45 PM
paudemge
bump..Any transmission experts around here?
