1991 Buick Park Ave. water pump removal
Old 11-20-05, 04:35 PM
I am trying to remove the water pump on my 1991 buick park ave. On the right hand side facing the pump are two 13mm bolts. they must are only accesable by use of a socket. one is accecable with a standard socket and ratchet however the other one is not. I am able to get a socket on the bolt however there is not enough room for any type of ratchet or breaker bar. I assume there is a special tool for this. Can anyone advise on this tool as in part # or name and where I might get it
Thanks Jim
Old 11-20-05, 11:53 PM
lemmyaraya
1/4 in. drive flexible socket. 6 pt. opening. Metric size 13mm.
Sears item #00943199000 Mfr. model #43199
use w/ 1/4" ext than adapt to 3/8s if needed
