Crank Position Sensor
Old 11-21-05, 08:36 AM
chevyastro4x4's Avatar
How would someone know if that sensor is going out, because i took my car in to see why it doesnt run very well in the cold. In the cold when you go start it, it will start right up but then it will die couple seconds later if you don't hold the gas down. and if it hasnt warmed up for about 30 mins i will park it in reverse and the whole car rattles then i go put it in drive and go hit the gas and no response for a couple seconds, then it goes.
Anyhelp would be very helpful.
Thanks
Old 11-21-05, 09:46 AM
Received 1,177 Likes on 1,135 Posts
I believe that a bad crankshaft positioning sensor would cause a code to be dumped into the computer. I would start by having that checked. I have heard that autozone stores will download codes for free in hopes that you then buy the parts to fix the problem from them.
Old 11-21-05, 10:02 AM
well the service engine light comes on but it goes off before i can get to auto zone, and it only comes on after drivin a long time.
Old 11-21-05, 11:55 AM
Even if the CEL goes off, there still should be a code in the computer.
Old 11-21-05, 12:19 PM
they said it was a softcode, not a hardcode
whatever that means
Old 11-21-05, 12:48 PM
Well, now you've got me stumped. But fear not, there are others here whose knowledge of cars dwarfs mine.
Old 11-21-05, 01:44 PM
I
I'm curious as to why you think it's a crankshaft position sensor related problem? I would be looking for vacuum leaks, EGR problems, and clean the TB and MAF well before I resorted to that.
Old 11-21-05, 02:05 PM
if it was a vacuum leak why does it only do it when its below freezing
Old 11-21-05, 07:39 PM
R
how bout the air intake tempature sensor?
Old 11-22-05, 12:32 AM
Sounds like the TB is icing up, I'm pretty sure you should have some type of heated air system. One of those tubes that send warm air into the air cleaner while the engine is cold.
Old 11-22-05, 06:58 AM
That My Car Doesn't Have
Old 11-22-05, 07:00 AM
Mine Has A Air Charge Temperature Sensor, And The Air Temp Sensor Is On The Block
Old 11-22-05, 09:53 AM
Not totally familiar with GM by know understand there is a pre-heater under the TB that heats mixture up. It is electric; it will also cause a check engine light if faulty
Old 11-22-05, 10:02 AM
Ok, i know when i plug it in at night it isnt as bad. but the guy said prolli because the oil is warm and the crank sensor has a better reading, but i think im going to replace it and have the ICM and the coils tested
