Pass Key II
Old 11-21-05, 10:52 AM
billbrock
Angry Pass Key II
I have a 1995 Chevy Lumina with the Pass Key II system on it. I used my car the other day it worked fine and when I went to use it later on that day it would not start and the security light was flashing and the volt light was on. How can you tell if it is the anti-theft system or something else if you cannot get the car to start?
Old 11-21-05, 11:57 AM
lemmyaraya
with batt above 12.4 ( use charger if needed ) turn key to start,
engine will start and stall leave key in run position for 15 mins
this will reset theft lock to roating mass of key used,
after 15 min turn key from run to start
Also if to many trys are made a 30 min lock out is set by comp
