astro van brakes
Old 11-22-05, 07:34 PM
dlaxdal
astro van brakes
I have replaced the front brakes on my 98 astro awd van many a times. Are there any heavy duty rotars for the front brakes. Any suggestions.
Old 11-23-05, 03:17 AM
ASEPartsman
How often are you replacing brakes? What Kind are you using?
I would recommend going with a quality made in the USA rotor such as Bendix or Raybestos Professional Grade. For the AWD they run about $75.00 a piece and for the 2 wheel drive they run about $90.00 a piece.
Also a good set of Bendix or Raybestos PG pads for the front will suit you well. They run about $40.00 a set for the AWD and $33.00 a set for the 2 wheel drive.
For just a little more Bendix makes a great SUV/Van brake pad that will set you back $56.00 a set for AWD and $46.00 a set for 2 wheel drive.
Also make sure your calipers are in good working order and that your brake hoses aren't deteriorated.
