Brakes need 2 presses to work well......
Old 11-23-05, 09:36 AM
C
98 Frontier 2wd pickup, I get a soft pedal on an initial press, but if I back off and then press again, I get a good pedal on the 2nd press (applying same pressure, pushing pedal the same distance, etc).
Fluid level is OK. Plenty of pad left. Ive checked the rubber hoses as best I could, didnt see any bulging/cracking/dryrot.
Any ideas would be appreciated.
Thanks!
-Chris
Old 11-23-05, 09:31 PM
Air
Sounds like air in system bleed it and inspect for leaks while you are at it.Sometimes you dont have time to pump brakes in a bad sitituation you need brake ASAP so I would get that fixed before it is to late and you crash.
Old 11-28-05, 09:31 PM
lf8828
Adjust Rear Brakes
Try Adjusting Rear Brakes Up
