serpentine change
Old 11-24-05, 04:51 PM
jetregan
serpentine change
Bought a new serpentine belt for my 98 olds regency only to find that the job is much more difficult than my 1988. Looks like GM stuck a motor mount in the middle.
Any help on procedure to remove obstacle would be appreciated.
Thanks Tim
Old 11-25-05, 04:36 AM
motor mount
You need to semi remove the upper motor mpunt so you can get the belt on.You will need to jack engine up a little.(thanks GM)
Old 11-25-05, 01:17 PM
jetregan
Thanks for your reply Michael
Does the mount come apart or should I remove it from the motor or frame?
Thanks again, Tim
Old 11-25-05, 02:42 PM
G
If it's like the one I ran into on a Pontiac, if you look closely, it may be spacer type mount. Check for a bolt in the wheel well area. Remove the bolt and tap the spacer out. Reverse after you have replaced the belt.
Old 11-26-05, 08:03 AM
jetregan
Thanks for the info, this turned into a bigger job than anticipated considering my limited knowledge and equipment. In the past, all I needed was a socket and a long breaker bar.
Not sure if moter mount will come apart but will give it a try next week.
Thanks again, Tim
