2000 Toyota Corolla Rear Defrost Fuse?
Old 11-25-05, 02:33 PM
emfstl
Can anyone tell me which fuse is for the rear defroster on a 2000 Toyota Corolla? I have tested all fuses I can find. Thank You
Old 11-25-05, 04:53 PM
Z
Red face
if the car came with it from the factory, it should tell you in your owners manual. If it is aftermarket, just trace the wires, but it might not have a fuse( hopefully it does )
Old 11-25-05, 09:10 PM
It is in the fuse panel in the left side dash, you may have to drop down the lower finish panel to gain access
Old 11-26-05, 08:18 AM
jatco's Avatar
Are you sure its a fuse..? or maybe the contacts or grid on the window has broken. - Just something else to check for.
