RHenry [Turn signal problems]
Old 11-26-05, 10:11 AM
Russell Henry
2002 Dodge Dakota-right signal??
Right signal got water in lens due to small accident. Had it replaced and signal quit working. Quit working again. Bulb good. Had new signal sending unit installed. Worked for a couple of days and quit again. Flashes quickly
and then sometimes it will work fine but mostly not. Need Advice
Last edited by Russell Henry; 11-26-05 at 10:20 AM. Reason: not enough detail in title
Old 11-27-05, 07:33 PM
try this
Turn on your flashers and see what bulb does not work it might be a back bulb.or front bulb you never said if you replaced front or back.
Old 11-28-05, 10:06 PM
Russell Henry
RHenry 2002 dakota right signal??
It is the front passenger side signal.
