Ignition Switch replacement
Old 11-27-05, 08:02 AM
R
My son lost the key to his 86 Bronco 2. A locksmith could not make a key & he said drill out the old one & replace it. We poped the switch cover off & drilled out what seems to be the pins that the key fit around but it will not come out any ideas?
Old 11-28-05, 09:31 AM
You are going to have to disassemble the the column down to the point where you can remove the lock cylinder. There should be a book available on line or at the library on how this particular unit comes apart.
Jeff
Old 12-09-05, 02:14 AM
lemmyaraya
You can take VIN and proof of owenship to a ford dealer and the can look up key codes and make a new keys
