'01 Galant Shutting Off After Start
Old 11-27-05, 07:52 PM
CanesFan08
I have a 2001 Mit Galant. As soon as you start the car it turns right back off. We have installed a new battery connection, and we know it's not the battery. This has been happening off and on for about 3 weeks. There is no problem in the starting aspect, turns right over. Not running rough, no smells, etc. No lights on. The other thing is that when it happened tonight, our keyless entry stopped working and our interior light is not coming on.
Suggestions??
Old 11-27-05, 11:45 PM
ASEPartsman
When you replaced the battery connection did you do both? Also make sure you are getting a good ground. If a ground cable is loose/corroded this can happen. Check it w/ a DMM and make sure there is not too much resistance.
