Russ-Power windows won't work
Old 11-28-05, 09:12 PM
Russell Henry
2002 Dodge Dakota. I tried to put window down during cold snap. It won't go up or down now. I could hear the motor make a noise. I took door panel off and small plastic pulley seems to be broken. Where can I find a good diagram of the door on the net as all automotive repair books are on backorder. Any suggestions on how to fix problem as dealership wants $300
for whole unit with motor as part not sold separately. Thanks
Old 11-29-05, 07:54 AM
X2C
You can go to any dealer that sells dodge and they will give you a blow up the assembly of how the door goes together and instead of going to the dealer for parts you can go to a junkyard or a parts store I know that would be alot cheaper good luck.
